I started the day by trimming the engine baffles to the contour of the engine cooling plenum. Next I riveted the aft left baffles together and riveted the oil cooler opening doubler plate. Lastly to see how the clearance was between the engine cooling plenum and the spark plugs I installed the ignition harness for the upper plugs for cylinders one and three.
Engine baffles trimmed to the plenum contour
Oil cooler opening doubler riveted
Emagair Pmag spark plug harness installation started
